radius-server-policy
Creates a RADIUS server policy and
enters its configuration mode
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
radius-server-policy <RADIUS-SERVER-POLICY-NAME>
Parameters
<RADIUS-SERVER-POLICY-NAME> |
Specify the RADIUS server policy name. If a policy with the specified
name does not exist, it is created. |
nx9500-6C8809(config)#radius-server-policy testRadiusServerPolicy
nx9500-6C8809(config-radius-server-policy-testRadiusServerPolicy)#?
Radius Configuration commands:
authentication Radius authentication
bypass Bypass Certificate Revocation List( CRL ) check
chase-referral Enable chasing referrals from LDAP server
crl-check Enable Certificate Revocation List( CRL ) check
ldap-agent LDAP Agent configuration parameters
ldap-group-verification Enable LDAP Group Verification setting
ldap-server LDAP server parameters
local RADIUS local realm
nas RADIUS client
no Negate a command or set its defaults
proxy RADIUS proxy server
session-resumption Enable session resumption/fast reauthentication by
using cached attributes
termination Enable Eap termination for proxy requests
use Set setting to use
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
no
Removes an existing RADIUS server policy |
For more information on RADIUS server
policy commands, see
RADIUS Policy.
